Comprehensive Guide to Installation and Configuration of MongoDB
by | MongoDB
Introduction to MongoDB
Overview
MongoDB is a popular NoSQL database system that uses a document-oriented data model. It’s designed for scalability, flexibility, and ease of development. This guide provides a practical approach to installing and configuring MongoDB on various operating systems including Windows, macOS, and Linux.
Installation
Windows Installation
Download MongoDB:
Select the latest MongoDB version and ensure the package is for Windows.
Install MongoDB:
Run the downloaded .msi file.
Follow the installation prompts and select “Complete” setup type.
During the installation, ensure you check the “Install MongoDB as a Service” option.
Setup Environment Variables:
Add the MongoDB bin directory to your system’s PATH environment variable:
C:Program FilesMongoDBServer<version>bin
Start MongoDB:
MongoDB should have been installed as a service and started automatically. You can verify it by checking services or using the command prompt:
net start MongoDB
macOS Installation
Install via Homebrew:
Open Terminal.
Install Homebrew if it’s not already installed:
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
Install MongoDB:
brew tap mongodb/brew
brew install mongodb-community
Start MongoDB:
Use Homebrew services to start MongoDB:
brew services start mongodb/brew/mongodb-community
Linux Installation (Ubuntu as an example)
Import the public key used by the package management system:
wget -qO - https://www.mongodb.org/static/pgp/server-5.0.asc | sudo apt-key add -
Create a list file for MongoDB:
echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/5.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-5.0.list
Reload local package database:
sudo apt-get update
Install MongoDB packages:
sudo apt-get install -y mongodb-org
Start MongoDB:
sudo systemctl start mongod
Enable MongoDB to start on boot:
sudo systemctl enable mongod
Configuration
Configuration File (mongod.conf)
The default location for the configuration file is:
Windows: C:Program FilesMongoDBServer<version>binmongod.cfg
macOS and Linux: /etc/mongod.conf
Editing the Configuration:
Use a text editor to edit mongod.conf. Below is an example configuration:
# mongod.conf
# Where and how to store data.
storage:
  dbPath: /var/lib/mongodb
  journal:
    enabled: true
# Where to write logging data.
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
# network interfaces
net:
  port: 27017
  bindIp: 127.0.0.1
# Process Management Options
processManagement:
  timeZoneInfo: /usr/share/zoneinfo
Apply Configuration Changes:
Restart MongoDB services for changes to take effect:
Windows:
net stop MongoDB
net start MongoDB
macOS and Linux:
sudo systemctl restart mongod
Verification
Verify MongoDB is running:
You can check if MongoDB is running by connecting to the MongoDB shell.
mongo
This opens the MongoDB shell and connects to the running MongoDB instance.
Check MongoDB status:
On Windows:
net start MongoDB
On macOS and Linux:
sudo systemctl status mongod
By following these detailed instructions, you will have MongoDB installed and configured on your operating system, ready for development and educational purposes.
Preparing Your Environment
In this section, we will cover preparing your system to work effectively with MongoDB after installation. This includes starting and stopping the MongoDB service, connecting to the MongoDB server, and creating a basic database and collection.
Starting and Stopping the MongoDB Service
On Windows
Starting MongoDB:
net start MongoDB
Stopping MongoDB:
net stop MongoDB
On macOS
Starting MongoDB using Homebrew:
Stopping MongoDB:
brew services stop mongodb/brew/mongodb-community
On Linux (systemd)
Starting MongoDB:
Stopping MongoDB:
sudo systemctl stop mongod
Connecting to MongoDB Server
After starting the MongoDB service, you can connect to the MongoDB server using the mongo shell.
Mongo Shell Command
mongo
Executing the above command in your terminal will start the MongoDB shell and connect to the default mongod instance running on localhost at port 27017.
Creating a Basic Database and Collection
Once connected to the MongoDB shell, you can create a database and a collection.
Create a Database
use myNewDatabase
The use command switches your context to myNewDatabase. If myNewDatabase does not exist, it will be created when you insert some data into it.
Create a Collection
db.createCollection("myNewCollection")
This command will create a collection named myNewCollection within the myNewDatabase.
Insert Data into Collection
db.myNewCollection.insertOne({ name: "MongoDB", type: "Database", year: 2009 })
This command inserts a single document into myNewCollection.
Verification
To verify that your database and collection have been created, you can use the following commands:
Show Databases
show dbs
Show Collections in the Current Database
show collections
Query the Collection
db.myNewCollection.find().pretty()
This will display the documents in a readable format.
Use these steps to ensure that your MongoDB environment is correctly prepared and that you can interact with the database as intended.
Part 3: Installing MongoDB on Windows
This section will provide a practical guide for installing MongoDB on a Windows operating system. Before starting, ensure that you have administrative access on your Windows machine.
Step-by-Step Installation Guide
1. Download MongoDB
Choose the version you want and select Windows as your operating system.
Click “Download” to get the .msi installer file.
2. Run the .msi Installer
Locate the downloaded .msi file and double-click to run it.
Follow the installation wizard steps:
Accept the license agreement.
For Setup Type, choose Complete.
3. Configure the Installation
In the Service Configuration step, you can choose to run MongoDB as a service:
Select “Install MongoD as a Service”.
Choose either “Run service as Network Service user” or “Run service as a local or domain user”.
Set the “Data Directory” to C:Program FilesMongoDBServer{Version}data.
Set the “Log Directory” to C:Program FilesMongoDBServer{Version}log.
Note: Make sure you have created the above-mentioned directories or choose an existing one.
(Optional) Install MongoDB Compass:
You can choose to install MongoDB Compass, which is a graphical interface for MongoDB.
Click on the checkbox to opt-in or opt-out.
Complete the installation by clicking the “Install” button.
4. Add MongoDB to the System Path
Open the Control Panel and go to System and Security -> System -> Advanced System Settings -> Environment Variables.
In the System variables section, find the Path variable and select it, then click “Edit”.
Click “New” and add the path to the MongoDB bin directory. By default, it is:
C:Program FilesMongoDBServer{Version}bin
Click “OK”, then “Apply”, and “OK” again to close all dialogs.
5. Verify the Installation
Open Command Prompt (cmd).
Type mongo --version and press Enter.
This should display the version of MongoDB installed, verifying a successful installation.
Configuration
1. Create Configuration File
Open a text editor and create a configuration file named mongo.cfg.
Add the following basic configuration, modifying paths as necessary:
systemLog:
    destination: file
    path: C:Program FilesMongoDBServer{Version}logmongod.log
    logAppend: true
storage:
    dbPath: C:Program FilesMongoDBServer{Version}data
net:
    bindIp: 127.0.0.1
    port: 27017
Save this file in your MongoDB directory, e.g., C:Program FilesMongoDBServer{Version}mongo.cfg.
2. Run MongoDB with Configuration File
Run the following command to start MongoDB with the configuration file:
mongod --config "C:Program FilesMongoDBServer{Version}mongo.cfg"
This will start the MongoDB server based on the configurations provided in the mongo.cfg file.
You have successfully installed and configured MongoDB on your Windows machine. You can now start building and managing your MongoDB databases.
Installing MongoDB on macOS
Here is a practical step-by-step guide to installing MongoDB on a macOS system.
Prerequisites
Ensure you have Homebrew installed on your macOS. If not, you can install it by running the following command in the Terminal:
Steps for Installation
  1. Update Homebrew
    Make sure your Homebrew is up to date by running:
    brew update
  2. Install MongoDB
    To install the latest version of MongoDB, execute the following command:
    brew install mongodb-community@5.0
    This will install MongoDB 5.0, which is the latest stable version at the time of writing.
  3. Verify the Installation
    Confirm that MongoDB has been installed correctly by checking the version:
    mongod --version
  4. Run MongoDB as a Service
    To start MongoDB automatically as a service, use the following commands:
    You can stop the service using:
    To check the status of the MongoDB service:
    brew services list
  5. Running MongoDB Manually
    If you prefer to run MongoDB manually, you can start the MongoDB server by running:
    mongod --config /usr/local/etc/mongod.conf
    To stop the MongoDB server, you can terminate the mongod process.
  6. Connect to MongoDB
    Open a new Terminal window/tab and launch the MongoDB shell to connect to the MongoDB instance:
    mongo
    This connects to the running instance of MongoDB and allows you to execute database operations.
Configuration
  1. Default Configuration File
    The default configuration file for MongoDB is usually located at /usr/local/etc/mongod.conf. You can edit this file to change configurations such as the data directory, log path, and bind IP address. Here is a quick way to open it via a text editor:
    nano /usr/local/etc/mongod.conf
    Example configuration snippet:
    storage:
    dbPath: /usr/local/var/mongodb
    systemLog:
    destination: file
    path: /usr/local/var/log/mongodb/mongo.log
    logAppend: true
    net:
    bindIp: 127.0.0.1
  2. Creating Data and Log Directories
    Ensure the directories specified in your configuration file exist:
    mkdir -p /usr/local/var/mongodb
    mkdir -p /usr/local/var/log/mongodb
    Adjust the permissions if needed:
    sudo chown -R `id -un` /usr/local/var/mongodb
    sudo chown -R `id -un` /usr/local/var/log/mongodb
Final Verification
Check the MongoDB server status by accessing the MongoDB shell and running sample queries or commands to verify full functionality:
mongo
You should see a prompt similar to:
MongoDB shell version v5.0.x
connecting to: mongodb://127.0.0.1:27017/
> show dbs
And that’s it! You’ve successfully installed and configured MongoDB on macOS.
Part 5: Installing MongoDB on Linux
Here’s how you can install MongoDB on a Linux system:
  1. Import the MongoDB public GPG Key
    wget -qO - https://www.mongodb.org/static/pgp/server-4.4.asc | sudo apt-key add -
  2. Create a list file for MongoDB
    echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.4 multiverse" |
    sudo tee /etc/apt/sources.list.d/mongodb-org-4.4.list
  3. Reload local package database
    sudo apt-get update
  4. Install MongoDB packages
  5. Start MongoDB
  6. Enable MongoDB to start on system reboot
  7. Verify that MongoDB has started
    You can check the status of the MongoDB service with the following command:
If everything is set up correctly, you should see a status that indicates MongoDB is active and running.
Configuration
After installation, you might want to configure MongoDB to suit your needs. Configuration files are generally found at /etc/mongod.conf.
Example Configuration (Optional Changes):
  1. Open Configuration File
    sudo nano /etc/mongod.conf
  2. Modify BindIp to Allow Remote Connections (Optional)
    net:
    bindIp: 0.0.0.0
  3. Set Up Authentication (Optional)
    Edit the Security section to enable authentication.
    security:
    authorization: "enabled"
  4. Restart MongoDB to Apply Changes
Security Considerations
  1. Create an Admin User:
    After enabling authentication, create an admin user:
    use admin
    db.createUser({
    user: "myAdmin",
    pwd: "securePassword",
    roles: [{ role: "userAdminAnyDatabase", db: "admin" }]
  2. Connecting with Authentication:
    When authentication is enabled, use the -u (username) and -p (password) options:
    mongo -u "myAdmin" -p "securePassword" --authenticationDatabase "admin"
Following these steps will install MongoDB on your Linux system, start the service, and optionally configure it for remote connections and authentication. Ensure to restart the MongoDB service after any configuration changes for them to take effect.
Post-Installation Configuration and Management of MongoDB
Configuration
  1. Modify mongod.conf Configuration File
    The mongod.conf file is where you set most of MongoDB’s operational parameters. Typical locations:
    • Linux: /etc/mongod.conf
    • Windows: C:Program FilesMongoDBServer<version>binmongod.cfg
    • macOS: /usr/local/etc/mongod.conf
    Example of a mongod.conf:
    storage:
    journal:
    enabled: true
    systemLog:
    destination: file
    logAppend: true
    net:
    port: 27017
    bindIp: 127.0.0.1 # Change to 0.0.0.0 to allow external connections
    security:
    authorization: enabled
  2. Enabling Authentication
    Verify that the authorization field is set to enabled under the security section:
    security:
    Restart the MongoDB service to apply the changes.
User Management
  1. Create Admin User
    Open the MongoDB shell and connect to the admin database:
    mongo
    use admin
    Create an admin user:
    db.createUser({
    user: "admin",
    pwd: "securepassword",
    roles: [ { role: "userAdminAnyDatabase", db: "admin" }, "readWriteAnyDatabase" ]
  2. Create Application-Specific User
    Switch to the target database:
    use myAppDB
    Create the user:
    db.createUser({
    user: "appUser",
    pwd: "appUserPwd",
    roles: [ { role: "readWrite", db: "myAppDB" } ]
Service Management
  1. Start and Stop MongoDB Service
    • Linux:
    • Windows:
      net start MongoDB
      net stop MongoDB
    • macOS:
  2. Enable MongoDB to Start on Boot
    • Linux:
    • Windows:
      sc config MongoDB start= auto
    • macOS:
Backup and Restore
  1. Backup MongoDB Database
    Use mongodump utility:
    mongodump --uri="mongodb://admin:securepassword@localhost:27017" --out=/path/to/backup/
  2. Restore MongoDB Database
    Use mongorestore utility:
    mongorestore --uri="mongodb://admin:securepassword@localhost:27017" /path/to/backup/
Monitoring and Maintenance
  1. Monitor the MongoDB Logs
    • Linux and macOS:
      tail -f /var/log/mongodb/mongod.log
    • Windows:
      Open the log file at the specified path in a text editor, typically:
      C:Program FilesMongoDBServer<version>logmongod.log
  2. Check Database Health
    Connect to MongoDB shell and run the following:
    use admin
    db.serverStatus()
    db.runCommand({ dbStats: 1 })
  3. Rotate Logs
    Issue a log rotation command as MongoDB does not rotate logs by default:
    db.adminCommand({ logRotate: 1 })
By following the steps outlined above, you can ensure that MongoDB is not only configured properly but also secured through user management and maintainable through proper service management and backup practices.
Mastering MongoDB Indexing Strategies
MongoDB Schema Design and Data Modeling
A comprehensive guide to mastering MongoDB schema design and data modeling. Explore best practices and strategies for creating efficient schemas tailored to your application’s needs.
