Introduction to Supply Chain Optimization and Inventory Management
Overview
Supply chain optimization aims to improve the efficiency of the entire supply chain from production to end-user, while Inventory Management focuses on balancing stock levels to meet demand without excessive surplus. Combining these concepts ensures that manufacturers can maintain optimal stock levels, reduce costs, and enhance productivity.
Objective
In this project, you will learn how to utilize Random Forests in R to predict the optimal inventory levels required to meet demand while minimizing costs. This includes setting up your R environment and dataset, preprocessing data, training the model, and evaluating its performance.
Setup Instructions
1. Installing Required Libraries
To get started, ensure you have R installed on your system. Use the following commands to install necessary packages:
install.packages("randomForest")
install.packages("caret")
install.packages("dplyr")
install.packages("ggplot2")
2. Loading Libraries
Load the libraries required for this project:
library(randomForest)
library(caret)
library(dplyr)
library(ggplot2)
Data Preparation
3. Loading the Dataset
Assume you have a dataset named inventory_data.csv
that contains historical inventory levels and relevant features. Load the dataset into R:
inventory_data <- read.csv("path_to_your_file/inventory_data.csv")
4. Exploring and Cleaning the Data
Inspect the dataset to understand its structure and handle any missing values or outliers:
# View the structure of the dataset
str(inventory_data)
# Summary statistics
summary(inventory_data)
# Handling missing values
inventory_data <- na.omit(inventory_data)
# Example of basic data cleaning: Removing outliers
inventory_data <- inventory_data %>% filter(column_x < quantile(column_x, 0.99))
Building the Random Forest Model
5. Splitting the Data
Divide the data into training and testing sets to evaluate the model performance:
set.seed(123) # For reproducibility
index <- createDataPartition(inventory_data$target_variable, p = 0.8, list = FALSE)
train_data <- inventory_data[index, ]
test_data <- inventory_data[-index, ]
6. Training the Model
Train the random forest model on the training data:
# Define the model
rf_model <- randomForest(target_variable ~ ., data = train_data, ntree = 100)
# Print the model summary
print(rf_model)
7. Evaluating the Model
Evaluate the model’s performance using the test dataset:
# Predictions on the test set
predictions <- predict(rf_model, newdata = test_data)
# Calculate performance metrics
confusionMatrix(predictions, test_data$target_variable)
# Plotting the Importance of Features
importance <- importance(rf_model)
varImportance <- data.frame(Variables = row.names(importance), Importance = importance[, 1])
# Plot
ggplot(varImportance, aes(x = reorder(Variables, -Importance), y = Importance)) +
geom_bar(stat = "identity") +
coord_flip()
By following these steps, you can set up and train a Random Forest model in R to predict optimal inventory levels, thereby enhancing supply chain optimization. This implementation provides practical, hands-on experience in applying predictive modeling techniques to real-world inventory management issues.
Basics of R Programming for Supply Chain Management
Here is a step-by-step implementation in R to optimize inventory levels for a manufacturing company using Random Forests.
Load Necessary Libraries
library(caret)
library(dplyr)
Load and Prepare Data
Assume you have historical inventory and demand data stored in a CSV file named inventory_data.csv
# Load data
data <- read.csv("inventory_data.csv")
# Inspect the data
str(data)
summary(data)
Data Preprocessing
Ensure data is clean and prepared for modeling.
# Handle missing values if any
data <- na.omit(data)
# Convert categorical variables to factors
data$Category <- as.factor(data$Category)
data$Product <- as.factor(data$Product)
# Split data into training and testing sets
trainIndex <- createDataPartition(data$Demand, p = 0.8, list = FALSE)
trainData <- data[trainIndex, ]
testData <- data[-trainIndex, ]
Train the Random Forest Model
Using historical data to train the model.
# Train Random Forest model
set.seed(123)
rf_model <- randomForest(Demand ~ ., data = trainData, ntree = 100)
# Print model summary
print(rf_model)
Evaluate the Model
Measure the model’s performance on the test set.
# Predict on the test set
predictions <- predict(rf_model, newdata = testData)
# Evaluate the model
confusionMatrix(predictions, testData$Demand)
# Calculate Mean Squared Error
mse <- mean((predictions - testData$Demand)^2)
cat("Mean Squared Error:", mse)
Optimize Inventory Levels
Using the trained model to predict future demand and optimize inventory levels accordingly.
# Predict future demand
future_demand <- predict(rf_model, newdata = testData) # Example newdata, replace with actual future data
# Assume a basic Economic Order Quantity (EOQ) formula for inventory optimization
# EOQ Formula: sqrt((2 * setup_cost * demand) / holding_cost)
# For simplicity, let's assume setup_cost = 50, holding_cost = 5
setup_cost <- 50
holding_cost <- 5
optimize_inventory <- function(demand) {
return(sqrt((2 * setup_cost * demand) / holding_cost))
# Optimize inventory levels based on predicted future demand
optimized_inventory_levels <- sapply(future_demand, optimize_inventory)
End of Implementation
This implementation provides a complete R script to load and prepare inventory data, train a Random Forest model to predict demand, evaluate the model, and optimize inventory levels based on the predicted demand.
Data Collection and Preprocessing of Sales Data
Data Collection
To collect sales data, assume we are reading it from a CSV file named “sales_data.csv” containing columns: Date, ProductID, Quantity, and SalesPrice. The necessary libraries for data manipulation are readr
and dplyr
library(readr)
library(dplyr)
# Read the sales data
sales_data <- read_csv("sales_data.csv")
Data Preprocessing
1. Handling Missing Values
Check for missing values in the dataset and handle them appropriately. Here, we will remove rows with any missing values for simplicity.
# Check for missing values
missing_values <- colSums(is.na(sales_data))
print(missing_values)
# Remove rows with missing values
sales_data_clean <- na.omit(sales_data)
2. Data Type Conversion
Ensure that the data types are correct (e.g., dates are in Date format, numeric columns are numeric).
# Convert Date to Date type
sales_data_clean$Date <- as.Date(sales_data_clean$Date, format="%Y-%m-%d")
# Convert ProductID to factor
sales_data_clean$ProductID <- as.factor(sales_data_clean$ProductID)
# Ensure Quantity and SalesPrice are numeric
sales_data_clean$Quantity <- as.numeric(sales_data_clean$Quantity)
sales_data_clean$SalesPrice <- as.numeric(sales_data_clean$SalesPrice)
3. Feature Engineering
Create new features from the existing data to help with predictive modeling. For instance, adding ‘SalesAmount’ (Quantity * SalesPrice) and extracting time-based features.
# Calculate SalesAmount
sales_data_clean <- sales_data_clean %>%
mutate(SalesAmount = Quantity * SalesPrice)
# Extract year, month, and day from Date
mutate(Year = as.numeric(format(Date, "%Y")),
Month = as.numeric(format(Date, "%m")),
Day = as.numeric(format(Date, "%d")))
4. Aggregation
Aggregate data to a granularity that makes sense for inventory prediction, such as daily or monthly sales per product.
# Aggregate monthly sales per product
monthly_sales <- sales_data_clean %>%
group_by(ProductID, Year, Month) %>%
summarise(TotalQuantity = sum(Quantity),
TotalSalesAmount = sum(SalesAmount),
.groups = 'drop')
5. Scaling Numerical Features
Scale numerical features for better performance in predictive modeling.
# Scale the TotalQuantity and TotalSalesAmount columns
scaled_features <- scale(monthly_sales %>% select(TotalQuantity, TotalSalesAmount))
# Combine scaled features with the rest of the data
monthly_sales_scaled <- monthly_sales %>%
select(ProductID, Year, Month) %>%
bind_cols(as_tibble(scaled_features), .name_repair = 'unique')
# The `monthly_sales_scaled` dataset is now ready for use in predictive modeling.
print(monthly_sales_scaled)
These steps cover the data collection and preprocessing needed to prepare the sales data for predictive modeling using Random Forests in R. The resultant monthly_sales_scaled
dataset can now be used in the subsequent steps of the project.
Exploratory Data Analysis (EDA) and Feature Engineering
Load the Data
# Load necessary libraries
library(ggplot2)
library(dplyr)
library(tidyr)
library(summarytools)
# Load the dataset
sales_data <- read.csv("sales_data.csv")Basic Summary
# Summary of dataset
dfSummary(sales_data)Missing Values Check
print(missing_values)Visualize Data Distribution
# Histograms for numeric variables
numeric_vars <- sales_data %>%
select_if(is.numeric)
for (var in colnames(numeric_vars)) {
ggplot(sales_data, aes_string(var)) +
geom_histogram(binwidth = 30, fill = "blue", color = "black") +
ggtitle(paste("Histogram of", var)) +
theme_minimal()
}Correlation Matrix
# Correlation matrix for numeric variables
cor_matrix <- cor(numeric_vars, use="complete.obs")
print(cor_matrix)
# Visualization of the Correlation Matrix
library(corrplot)
corrplot(cor_matrix, method = "circle")Outliers Detection
# Boxplots for outlier detection
geom_boxplot(fill = "orange", color = "black") +
ggtitle(paste("Boxplot of", var)) +
theme_minimal()
Feature Engineering
Date Features Extraction
# Convert to date format and extract features
sales_data$Date <- as.Date(sales_data$Date, format = "%Y-%m-%d")
sales_data$Year <- format(sales_data$Date, "%Y")
sales_data$Month <- format(sales_data$Date, "%m")
sales_data$DayOfWeek <- format(sales_data$Date, "%A")Lag Features
# Create lag features for sales
sales_data <- sales_data %>%
arrange(Date) %>%
group_by(ProductID) %>%
mutate(Sales_Lag1 = lag(Sales, 1),
Sales_Lag2 = lag(Sales, 2),
Sales_Lag3 = lag(Sales, 3)) %>%
ungroup()Rolling Mean Features
# Calculate rolling mean of sales
arrange(Date) %>%
mutate(Rolling_Mean_3 = rollmean(Sales, 3, fill = NA, align = "right"),
Rolling_Mean_7 = rollmean(Sales, 7, fill = NA, align = "right")) %>%
ungroup()One-Hot Encoding for Categorical Variables
# One-hot encode categorical variables
mutate_at(vars(ProductCategory, DayOfWeek), factor) %>%
tidyr::spread(key = ProductCategory, value = ProductCategory, fill = 0) %>%
tidyr::spread(key = DayOfWeek, value = DayOfWeek, fill = 0)Final Preprocessing Steps
# Handle missing values resulting from lag and rolling features
sales_data[is.na(sales_data)] <- 0
# Drop unnecessary columns
select(-Date)
Now the data is ready for predictive modeling using Random Forests.
Introduction to Machine Learning and Random Forests
In this section, you will learn how to apply Machine Learning, specifically Random Forests, to optimize inventory levels for a manufacturing company using R.
Random Forests in R for Predictive Modeling
Random Forests is an ensemble learning method used for classification and regression tasks. In this project, we’ll focus on regression to predict inventory levels.
Step-by-Step Implementation
Step 1: Load Necessary Libraries
library(caret)
library(tidyverse)
Step 2: Prepare the Data
Assuming you have a preprocessed dataset named sales_data
with the target column inventory_level
# Split the data into training and testing sets
set.seed(123)
training_indices <- createDataPartition(sales_data$inventory_level, p = 0.8, list = FALSE)
train_data <- sales_data[training_indices, ]
test_data <- sales_data[-training_indices, ]
Step 3: Train the Random Forest Model
# Train the Random Forest model
rf_model <- randomForest(inventory_level ~ ., data = train_data, ntree = 100, mtry = 3, importance = TRUE)
Step 4: Evaluate Model Performance
# Predict on test data
# Calculate Mean Squared Error (MSE)
mse <- mean((predictions - test_data$inventory_level)^2)
print(paste("Mean Squared Error: ", mse))
# Calculate R^2
r2 <- caret::R2(predictions, test_data$inventory_level)
print(paste("R^2: ", r2))
Step 5: Feature Importance
# Plot the importance of variables
varImpPlot(rf_model)
Step 6: Application: Predict Future Inventory Levels
Assuming you have a new dataframe new_data
that does not include the target variable inventory_level
# Predict future inventory levels
future_predictions <- predict(rf_model, newdata = new_data)
# Add the predictions to the new_data dataframe
new_data <- new_data %>%
mutate(predicted_inventory_level = future_predictions)
# View the dataframe with predictions
print(new_data)
You’ve successfully completed an introduction to Machine Learning and applied Random Forests to predict inventory levels in R. Moving forward, you can enhance this model further by tuning hyperparameters, cross-validation, and incorporating additional features.
Building Random Forest Models to Predict Demand
1. Load Libraries and Data
library(caret)
# Load the preprocessed sales data (assuming data frame is called `sales_data`)
# sales_data <- read.csv("path_to_your_data.csv")
2. Data Preparation
# Convert categorical variables to factors if necessary
sales_data$ProductCategory <- as.factor(sales_data$ProductCategory)
sales_data$StoreID <- as.factor(sales_data$StoreID)
# Split data into training and test sets
set.seed(123) # for reproducibility
trainIndex <- createDataPartition(sales_data$Demand, p = .8,
list = FALSE,
times = 1)
trainData <- sales_data[ trainIndex,]
testData <- sales_data[-trainIndex,]
3. Train the Random Forest Model
# Train the model
set.seed(123)
rf_model <- randomForest(Demand ~ ., data=trainData, ntree=500, mtry=4, importance=TRUE)
print(rf_model)
print(importance(rf_model))
4. Evaluate Model Performance
predicted_demand <- predict(rf_model, testData)
mae <- mean(abs(predicted_demand - testData$Demand))
rmse <- sqrt(mean((predicted_demand - testData$Demand)^2))
cat("Mean Absolute Error (MAE): ", mae, "\n")
cat("Root Mean Squared Error (RMSE): ", rmse, "\n")
5. Variable Importance
# Plot variable importance
6. Save the Model
# Save the trained model to disk
saveRDS(rf_model, file = "random_forest_demand_model.rds")
# To load the model later, use:
# rf_model <- readRDS("random_forest_demand_model.rds")
7. Apply Model to New Data
# Assuming `new_data` is a data frame containing the new data for prediction
# new_data <- read.csv("path_to_new_data.csv")
# Convert new_data categorical variables to factors
new_data$ProductCategory <- as.factor(new_data$ProductCategory)
new_data$StoreID <- as.factor(new_data$StoreID)
# Predict demand for new data
new_predicted_demand <- predict(rf_model, new_data)
# Add predictions to the new_data data frame
new_data$PredictedDemand <- new_predicted_demand
# View the new data with predictions
print(head(new_data))
By following the steps outlined above, you will have successfully built and evaluated a Random Forest model to predict demand. This model can now be used to predict demand for new data, thereby optimizing inventory levels for your manufacturing company.
Model Evaluation and Optimization Techniques
Model Evaluation
After building the Random Forest model to predict demand, it is essential to evaluate its performance. This section provides a practical implementation for evaluating and optimizing the random forest model using standard techniques.
Evaluation Metrics:
- Mean Absolute Error (MAE): The average of the absolute errors
- Mean Squared Error (MSE): The average of the square of the errors
- Root Mean Squared Error (RMSE): The square root of the average of the square of the errors
- R-squared (R²): The proportion of the variance in the dependent variable that is predictable from the independent variables.
Confusion Matrix: Since it is a regression problem, a confusion matrix typically used for classification problems is not applicable. However, if you categorize demand (e.g., low, medium, high), you can use it.
Code Implementation in R
# Import libraries
library(Metrics)
# Assuming you have a trained random forest model `rf_model` and test dataset `test_data`
# Predict test data
# Actual values
actuals <- test_data$actual_demand # Replace 'actual_demand' with your actual target variable name
# Compute evaluation metrics
mae_value <- mae(actuals, predictions)
mse_value <- mse(actuals, predictions)
rmse_value <- rmse(actuals, predictions)
r_squared_value <- cor(actuals, predictions)^2
# Print the evaluation metrics
cat("Mean Absolute Error (MAE):", mae_value, "\n")
cat("Mean Squared Error (MSE):", mse_value, "\n")
cat("Root Mean Squared Error (RMSE):", rmse_value, "\n")
cat("R-squared (R²):", r_squared_value, "\n")
Model Optimization
To optimize the implementation of the Random Forest model, techniques such as hyperparameter tuning should be used. Key hyperparameters for Random Forest include:
- Number of trees (
ntree
) - Number of variables randomly sampled as candidates (
mtry
) - Maximum number of nodes (
maxnodes
Hyperparameter Tuning Using Grid Search
This section provides a practical implementation for hyperparameter tuning using Grid Search in R.
# Define a grid of hyperparameters
hyper_grid <- expand.grid(
mtry = c(2, 4, 6, 8),
ntree = c(100, 200, 300),
maxnodes = c(30, 50, 70),
OOB_RMSE = 0
# Grid search
for(i in 1:nrow(hyper_grid)) {
formula = actual_demand ~ ., # Replace 'actual_demand' with your actual target variable name
data = train_data, # Replace 'train_data' with your actual training dataset
mtry = hyper_grid$mtry[i],
ntree = hyper_grid$ntree[i],
maxnodes = hyper_grid$maxnodes[i]
# Out of Bag Error (OOB) is a useful error estimate in the context of Random Forests
hyper_grid$OOB_RMSE[i] <- sqrt(model$mse[which.min(model$mse)])
# Best hyperparameters
best_params <- hyper_grid[which.min(hyper_grid$OOB_RMSE),]
cat("Best Parameters: \n")
print(best_params)
# Train the final model with the best parameters
final_model <- randomForest(
mtry = best_params$mtry,
ntree = best_params$ntree,
maxnodes = best_params$maxnodes
# Print final model details
print(final_model)
By following these implementations, you can effectively evaluate and optimize your Random Forest model to enhance the accuracy of demand predictions, thereby optimizing inventory levels.
Part 8: Integrating Model Predictions with Inventory Management Systems in R
Suppose you have already built and optimized a Random Forest model to predict demand. Now, you need to integrate these predictions into your Inventory Management System (IMS).
Dependencies
library(dplyr)
library(DBI)
library(RSQLite)
Step 1: Load the Random Forest Model
# Load the saved Random Forest model
load("random_forest_model.RData")
Step 2: Predict Demand
First, obtain the latest feature set that you need for predictions.
# Assume `new_data` is the new data frame ready for predictions
predicted_demand <- predict(random_forest_model, newdata = new_data)
new_data$predicted_demand <- predicted_demand
Step 3: Update Inventory Management System (IMS) Database
Assuming your inventory management system uses an SQLite database, you can integrate the predictions as follows:
# Connect to the SQLite database
con <- dbConnect(RSQLite::SQLite(), dbname = "ims_database.sqlite")
# Update the predicted demand in the IMS
dbWriteTable(con, "predicted_demand_table", new_data, append = TRUE, row.names = FALSE, overwrite = TRUE)
# Optionally, if you already have an inventory table in your database:
inventory_table <- dbReadTable(con, "inventory_table")
# Join the inventory table with the predicted demand to make adjustments
updated_inventory <- inventory_table %>%
inner_join(new_data, by = "product_id") %>%
mutate(predicted_inventory_level = current_inventory_level - predicted_demand)
# Update the inventory table in database
dbWriteTable(con, "updated_inventory_table", updated_inventory, overwrite = TRUE, row.names = FALSE)
# Clean up and close the database connection
dbDisconnect(con)
Step 4: Automate the Process
Use cronR
package to schedule the prediction and update process.
library(cronR)
# Create an R script that includes the prediction and integration code
fileConn <- file("update_inventory.R")
writeLines(c(
"library(randomForest)",
"library(dplyr)",
"library(DBI)",
"library(RSQLite)",
'load("random_forest_model.RData")',
'# Load new data from source, this line will vary with your data source',
'new_data <- read.csv("new_data.csv")',
'predicted_demand <- predict(random_forest_model, newdata = new_data)',
'new_data$predicted_demand <- predicted_demand',
'con <- dbConnect(RSQLite::SQLite(), dbname = "ims_database.sqlite")',
'dbWriteTable(con, "predicted_demand_table", new_data, append = TRUE, row.names = FALSE, overwrite = TRUE)',
'inventory_table <- dbReadTable(con, "inventory_table")',
'updated_inventory <- inventory_table %>%
mutate(predicted_inventory_level = current_inventory_level - predicted_demand)',
'dbWriteTable(con, "updated_inventory_table", updated_inventory, overwrite = TRUE, row.names = FALSE)',
'dbDisconnect(con)'
), fileConn)
close(fileConn)
# Create a cron job to run this script daily
cmd <- cron_rscript("update_inventory.R", rscript_args = "")
cron_add(cmd, frequency = 'daily', at = "00:00")
By the end of these steps, your predictions should be integrated into the Inventory Management System seamlessly, helping the manufacturing company optimize inventory levels efficiently. Make sure to adjust paths and variable names as per your actual data and environment setup.
Real-World Case Studies of Inventory Optimization
Case Study: XYZ Manufacturing Company
Problem Statement
XYZ Manufacturing Company faces challenges in managing its inventory levels efficiently, leading to either stockouts or overstock situations. This results in increased operational costs and loss of customer satisfaction. The goal is to develop a predictive model using Random Forests in R to optimize inventory levels by accurately forecasting demand.
Implementation Steps
Data Preparation
Load and preprocess historical sales data for the model.
library(dplyr)
# Reading the dataset
# Data Preprocessing
sales_data_clean <- sales_data %>%
filter(!is.na(Sales)) %>% # Removing rows with missing sales values
mutate(Date = as.Date(Date)) # Converting Date to Date format
Feature Engineering
Create relevant features that will aid in demand prediction.
# Create additional features
DayOfWeek = as.numeric(format(Date, "%u")),
WeekOfYear = as.numeric(format(Date, "%U")))
# Aggregate sales by relevant time periods
group_by(Year, Month, Product_ID) %>%
summarize(Total_Sales = sum(Sales), .groups = 'drop')
Training and Testing Split
Split the data into training and testing sets for validation.
set.seed(123)
train_indices <- sample(1:nrow(monthly_sales), 0.8 * nrow(monthly_sales))
train_data <- monthly_sales[train_indices,]
test_data <- monthly_sales[-train_indices,]
Build Random Forest Model
Train the Random Forest model on the training data.
# Build the Random Forest model
rf_model <- randomForest(Total_Sales ~ Year + Month + WeekOfYear + Product_ID,
data = train_data,
ntree = 100,
mtry = 3,
importance = TRUE)
print(rf_model)
Model Evaluation
Evaluate the model performance using the testing data.
# Make predictions on the testing set
actuals <- test_data$Total_Sales
mse <- mean((predictions - actuals)^2)
mae <- mean(abs(predictions - actuals))
cat("Mean Squared Error: ", mse, "\n")
cat("Mean Absolute Error: ", mae, "\n")
Integration with Inventory Management System
Generate predictions for future periods and integrate them into the inventory management system.
# Assuming future periods are represented by a dataframe 'future_periods'
future_periods <- data.frame(
Year = c(2023, 2023, 2023),
Month = c(1, 2, 3),
WeekOfYear = c(1, 5, 9),
Product_ID = c(101, 101, 101)
future_predictions <- predict(rf_model, newdata = future_periods)
# Final predicted sales
future_periods$Predicted_Sales <- future_predictions
# View future demand predictions
print(future_periods)
This case study demonstrated the implementation of inventory optimization using a Random Forest model in R. The model was trained on historical sales data, evaluated for performance, and used to predict future demand. These predictions can be integrated into the inventory management system to optimize inventory levels, thereby reducing costs and increasing customer satisfaction.
Future Trends and Enhancements in Supply Chain Optimization
Advanced Predictive Analytics with Random Forests
1. Incorporating More Granular Data
To incorporate more granular data, you might want to process data at a more detailed level, such as daily sales data or data segmented by geographical region.
# Load and preprocess more granular data
daily_sales_data <- read.csv("daily_sales_data.csv")
daily_sales_data$Date <- as.Date(daily_sales_data$Date, format="%Y-%m-%d")
# Train a Random Forest model with this granular data
set.seed(123)
granular_rf_model <- randomForest(Sales ~ ., data=daily_sales_data, importance=TRUE, ntree=500)
# Feature importance plot
varImpPlot(granular_rf_model)
2. Real-time Data Integration
Real-time data integration can be achieved through APIs or streaming data sources.
# Sample code to integrate real-time data
# This is a placeholder for actual data fetching implementation
real_time_sales_data <- fetch_real_time_data(api_endpoint = "https://api.example.com/sales")
# Predict on real-time data
real_time_predictions <- predict(granular_rf_model, newdata=real_time_sales_data)
# Integrate these predictions with existing inventory management systems
integrate_predictions_with_inventory(real_time_predictions)
Note: fetch_real_time_data
and integrate_predictions_with_inventory
are placeholders for actual functions that would interface with APIs or inventory systems.
3. Using Ensemble Learning
Ensemble methods involve combining multiple models to improve predictive performance.
# Example of creating an ensemble model combining Random Forest with another model (e.g., Gradient Boosting)
library(gbm)
# Train a Gradient Boosting Model
set.seed(123)
gbm_model <- gbm(Sales ~ ., data=daily_sales_data, distribution="gaussian", n.trees=500, interaction.depth=4)
# Combine predictions from both models
rf_predictions <- predict(granular_rf_model, newdata=daily_sales_data)
gbm_predictions <- predict(gbm_model, newdata=daily_sales_data, n.trees=500)
# Example of a simple ensemble by averaging the predictions
ensemble_predictions <- (rf_predictions + gbm_predictions) / 2
4. Leveraging External Data Sources
Incorporate external data sources like weather data, economic indicators, and social media trends.
# Load and preprocess external data
weather_data <- read.csv("weather_data.csv")
economic_data <- read.csv("economic_data.csv")
# Merge external data with sales data
merged_data <- merge(daily_sales_data, weather_data, by="Date")
merged_data <- merge(merged_data, economic_data, by="Date")
# Train Random Forest model with the merged data
set.seed(123)
enhanced_rf_model <- randomForest(Sales ~ ., data=merged_data, importance=TRUE, ntree=500)
print(enhanced_rf_model)
Implementation
- Granular Data Collection: Enhance the granularity of the data being collected.
- Real-time Processing: Develop APIs or data streaming mechanisms and integrate them with predictive models.
- Ensemble Learning: Combine predictions from multiple models for better accuracy.
- External Data Sources: Augment inventory data with relevant external data sources for improved demand forecasting.
Summary
By incrementally adopting these advanced techniques and technologies, the supply chain optimization efforts can be significantly enhanced, resulting in more accurate demand predictions and efficient inventory management.
