Introduction to SQL and Data Science
Overview
SQL (Structured Query Language) is a domain-specific language used in programming and designed for managing data held in a relational database management system (RDBMS). In data science, SQL is indispensable for manipulating and querying data efficiently. The following sections will guide you through foundational SQL concepts and their application in data science.
Setup Instructions
1. Installation
MySQL
For practical implementation, you will need a relational database. Follow the steps below to install MySQL, a popular RDBMS.
Download MySQL:
- Go to the MySQL website.
- Download the MySQL Installer suitable for your operating system.
Install MySQL:
- Run the downloaded installer.
- Follow the setup wizard instructions. Choose the “Developer Default” setup type for a typical data science environment.
- Set root password and note it down for future use.
- Complete the installation.
Alternative: SQLite
SQLite is a self-contained, serverless SQL database engine. It’s easier to set up than MySQL and perfect for beginners.
Download SQLite:
- Go to the SQLite download page.
- Download the precompiled binary suitable for your system.
Install SQLite:
- For Windows, unzip the binary and put it in a directory in your PATH.
- For macOS, you can use Homebrew:
brew install sqlite
2. Tools
MySQL Workbench
Download and install MySQL Workbench, a graphical tool for MySQL.
SQLite Browser
Install DB Browser for SQLite, which provides a visual interface to interact with SQLite databases.
Basic SQL Operations
1. Creating a Database
MySQL
CREATE DATABASE data_science_db;
USE data_science_db;
SQLite
-- In your SQLite shell or DB Browser, simply open a new database file
.open data_science_db.sqlite
2. Creating Tables and Inserting Data
Create Table
CREATE TABLE customers (
customer_id INT PRIMARY KEY,
name VARCHAR(50),
email VARCHAR(50),
signup_date DATE
Insert Data
INSERT INTO customers (customer_id, name, email, signup_date)
VALUES
(1, 'John Doe', 'john.doe@example.com', '2020-01-01'),
(2, 'Jane Smith', 'jane.smith@example.com', '2020-02-01');
3. Querying Data
Select Query
SELECT * FROM customers;
Conditional Query
SELECT name, email FROM customers WHERE signup_date > '2020-01-31';
4. Updating and Deleting Data
Update Data
UPDATE customers SET email = 'jane.new@example.com' WHERE customer_id = 2;
Delete Data
DELETE FROM customers WHERE customer_id = 1;
Data Science Applications of SQL
Aggregation and Group By
Total Customers by Signup Month
SELECT COUNT(*) AS total_customers, MONTH(signup_date) AS signup_month
FROM customers
GROUP BY signup_month;
Joining Tables
Suppose we have another table, orders
CREATE TABLE orders (
order_id INT PRIMARY KEY,
customer_id INT,
order_amount DECIMAL(10, 2),
order_date DATE,
FOREIGN KEY (customer_id) REFERENCES customers(customer_id)
Insert some data into orders
INSERT INTO orders (order_id, customer_id, order_amount, order_date)
VALUES
(101, 1, 100.00, '2020-01-15'),
(102, 2, 200.00, '2020-02-20');
Query with Join
SELECT customers.name, orders.order_id, orders.order_amount
FROM customers
JOIN orders ON customers.customer_id = orders.customer_id;
Advanced SQL: Subqueries and CTEs
Subquery for Average Order Amount
SELECT name, (
SELECT AVG(order_amount)
FROM orders
WHERE orders.customer_id = customers.customer_id
) AS avg_order_amount
FROM customers;
Common Table Expressions (CTEs)
WITH OrderTotals AS (
SELECT customer_id, SUM(order_amount) AS total_amount
FROM orders
GROUP BY customer_id
SELECT customers.name, OrderTotals.total_amount
FROM customers
JOIN OrderTotals ON customers.customer_id = OrderTotals.customer_id;
By following through this structured approach, you will gain a foundational understanding of SQL and its applications in data science.
Working with Databases and Tables in SQL
This segment focuses on practical implementations of how to efficiently create, modify, and interact with databases and tables within SQL, specifically tailored for data science applications.
Creating a Database
CREATE DATABASE DataScienceDB;
Selecting a Database
USE DataScienceDB;
Creating Tables
Example: Creating a Table for Storing User Data
CREATE TABLE Users (
UserID INT PRIMARY KEY AUTO_INCREMENT,
UserName VARCHAR(50) NOT NULL,
Email VARCHAR(100) UNIQUE NOT NULL,
JoinDate DATE NOT NULL
Example: Creating a Table for Storing Transaction Data
CREATE TABLE Transactions (
TransactionID INT PRIMARY KEY AUTO_INCREMENT,
UserID INT,
TransactionAmount DECIMAL(10, 2),
TransactionDate DATE,
FOREIGN KEY (UserID) REFERENCES Users(UserID)
Inserting Data into Tables
Insert Data into Users Table
INSERT INTO Users (UserName, Email, JoinDate)
VALUES ('JohnDoe', 'john.doe@example.com', '2023-01-15');
Insert Data into Transactions Table
INSERT INTO Transactions (UserID, TransactionAmount, TransactionDate)
VALUES (1, 150.75, '2023-03-10');
Querying Data from Tables
Simple SELECT Query
SELECT * FROM Users;
Filtering Data with WHERE Clause
SELECT * FROM Transactions
WHERE TransactionAmount > 100.00;
Joining Tables
SELECT Users.UserName, Transactions.TransactionAmount, Transactions.TransactionDate
FROM Users
JOIN Transactions ON Users.UserID = Transactions.UserID;
Updating Data in Tables
Update a User’s Email
UPDATE Users
SET Email = 'new.email@example.com'
WHERE UserName = 'JohnDoe';
Deleting Data from Tables
Delete a User
DELETE FROM Users
Altering Tables
Adding a New Column
ALTER TABLE Users
ADD COLUMN LastLoginDate DATETIME;
Modifying an Existing Column
ALTER TABLE Users
MODIFY COLUMN Email VARCHAR(150) NOT NULL;
Dropping a Column
ALTER TABLE Users
DROP COLUMN LastLoginDate;
Aggregating Data
Counting the Number of Users
SELECT COUNT(*) FROM Users;
Summing Transaction Amounts
SELECT SUM(TransactionAmount) FROM Transactions;
Grouping Data
Group Transactions by User
SELECT UserID, SUM(TransactionAmount) as TotalSpent
FROM Transactions
GROUP BY UserID;
Indexing for Performance
Creating an Index on UserName
CREATE INDEX idx_user_name ON Users(UserName);
Practical Use Case: Summary of Daily Transactions
Creating a Summary Table
CREATE TABLE DailyTransactionSummary (
TransactionDate DATE PRIMARY KEY,
TotalTransactions INT,
TotalAmount DECIMAL(10, 2)
Populating the Summary Table
INSERT INTO DailyTransactionSummary (TransactionDate, TotalTransactions, TotalAmount)
SELECT TransactionDate, COUNT(*), SUM(TransactionAmount)
FROM Transactions
GROUP BY TransactionDate;
This practical implementation covers the essential SQL techniques needed for managing databases and performing key operations on tables, fostering the ability to handle large data sets and derive meaningful insights in data science contexts.
Data Selection and Filtering Techniques in SQL
1. SELECT Statements
Basic SELECT
-- Select all columns from a table
SELECT *
FROM employees;
Selecting Specific Columns
-- Select specific columns from a table
SELECT first_name, last_name, department
FROM employees;
2. Filtering Data with WHERE
Basic Filtering with WHERE
-- Select employees from the 'Sales' department
SELECT *
FROM employees
WHERE department = 'Sales';
Using Comparison Operators
-- Select employees with a salary greater than 50000
SELECT *
FROM employees
WHERE salary > 50000;
Using Multiple Conditions with AND/OR
-- Select employees from 'Sales' department with salary more than 50000
SELECT *
FROM employees
AND salary > 50000;
-- Select employees from 'Sales' or 'Marketing' department
SELECT *
FROM employees
OR department = 'Marketing';
3. Advanced Filtering
Using IN
-- Select employees from the 'Sales', 'Marketing' or 'HR' departments
SELECT *
FROM employees
WHERE department IN ('Sales', 'Marketing', 'HR');
Using BETWEEN
-- Select employees with a salary between 40000 and 60000
SELECT *
FROM employees
WHERE salary BETWEEN 40000 AND 60000;
Using LIKE for Pattern Matching
-- Select employees whose names start with 'J'
SELECT *
FROM employees
WHERE first_name LIKE 'J%';
-- Select employees whose names contain 'son'
SELECT *
FROM employees
WHERE last_name LIKE '%son%';
4. NULL Handling
IS NULL and IS NOT NULL
-- Select employees where the email is not provided
SELECT *
FROM employees
WHERE email IS NULL;
-- Select employees where the phone number is provided
SELECT *
FROM employees
WHERE phone_number IS NOT NULL;
5. Combining Conditions with ORDER BY
Basic Sorting
-- Select all employees sorted by last name
SELECT *
FROM employees
ORDER BY last_name;
Sorting with Multiple Columns
-- Select all employees sorted by department and then by salary (descending)
SELECT *
FROM employees
ORDER BY department, salary DESC;
6. LIMIT for Sampling Data
Limiting Results
-- Select the first 10 employees
SELECT *
FROM employees
LIMIT 10;
Pagination with OFFSET
-- Select employees for the second page (assuming 10 records per page)
SELECT *
FROM employees
ORDER BY last_name
LIMIT 10 OFFSET 10;
These SQL techniques are essential for data selection and filtering, enabling efficient data retrieval and manipulation for data science tasks. They form a core part of querying databases, allowing you to extract relevant datasets for analysis.
Advanced Data Aggregation and Grouping in SQL
In this section, we’ll cover advanced SQL techniques for data aggregation and grouping, tailored for data science applications. These techniques are crucial for summarizing large datasets and uncovering insights.
Grouping Data: GROUP BY
The GROUP BY
clause is used to arrange identical data into groups. This is often combined with aggregate functions like SUM
, COUNT
, AVG
, MIN
, and MAX
Example: Basic Grouping
Let’s say we have a table sales
SELECT product_id, SUM(sales_amount) as total_sales
FROM sales
GROUP BY product_id;
This query calculates the total sales for each product.
Filtering Groups: HAVING
The HAVING
clause filters groups based on a condition (similar to WHERE
, but for groups).
Example: Filtering Groups
FROM sales
GROUP BY product_id
HAVING SUM(sales_amount) > 1000;
This query returns only products with total sales greater than 1000.
Using Window Functions for Advanced Aggregation
Window functions allow computation across a set of table rows that are related to the current row. They don’t collapse rows into groups.
Example: Calculating a Rolling Average
Consider we have a sales
table with columns order_date
, product_id
, and sales_amount
. To calculate a rolling average of sales over the last 7 days:
SELECT
order_date,
product_id,
sales_amount,
AVG(sales_amount) OVER (
PARTITION BY product_id
ORDER BY order_date
ROWS BETWEEN 6 PRECEDING AND CURRENT ROW
) as rolling_avg
FROM sales;
This query computes a 7-day rolling average of sales for each product.
Using CTEs for Complex Aggregations
Common Table Expressions (CTEs) allow for intermediate results which simplify complex queries.
Example: Cumulative Sum
WITH product_sales AS (
SELECT
product_id,
order_date,
sales_amount,
SUM(sales_amount) OVER (
ORDER BY order_date
ROWS BETWEEN UNBOUNDED PRECEDING AND CURRENT ROW
) as cumulative_sales
FROM sales
SELECT * FROM product_sales;
This query computes a cumulative sum of sales for each product.
Combining Multiple Aggregations
Sometimes, multiple aggregations are needed in a single result set.
Example: Multiple Aggregations
SELECT
product_id,
COUNT(*) as total_orders,
SUM(sales_amount) as total_sales,
AVG(sales_amount) as avg_sales,
MAX(sales_amount) as max_sales,
MIN(sales_amount) as min_sales
FROM sales
This query calculates various aggregations for each product.
Advanced data aggregation and grouping techniques in SQL are powerful tools for data scientists. By leveraging functions like GROUP BY
, HAVING
, window functions, CTEs, and combining multiple aggregations, one can perform complex and insightful data analysis efficiently. These examples should provide a solid foundation for applying these techniques in real-life scenarios.
Data Cleaning and Preparation in SQL
To effectively clean and prepare your data in SQL, follow these practical steps using SQL queries. Each step is crucial in ensuring the quality and usability of your dataset for downstream data science applications.
1. Handling Missing Values
Identify Missing Values
SELECT *
FROM your_table
WHERE column_name IS NULL;
Fill Missing Values
To replace NULL values with a default value:
UPDATE your_table
SET column_name = 'default_value'
Alternatively, to fill NULL values for numerical columns:
UPDATE your_table
SET column_name = 0
2. Removing Duplicates
Identify Duplicates
SELECT column_name, COUNT(*)
FROM your_table
GROUP BY column_name
HAVING COUNT(*) > 1;
Remove Duplicates
To remove exact duplicate rows:
DELETE FROM your_table
WHERE rowid NOT IN (
SELECT MIN(rowid)
FROM your_table
GROUP BY column_name1, column_name2, ...);
3. Standardizing Data Formats
Standardize Text Case
To convert a text column to lowercase:
UPDATE your_table
SET text_column = LOWER(text_column);
To convert a text column to uppercase:
UPDATE your_table
SET text_column = UPPER(text_column);
Standardize Date Formats
To convert dates to a standard format (e.g., ‘YYYY-MM-DD’):
UPDATE your_table
SET date_column = STRFTIME('%Y-%m-%d', date_column);
4. Removing Outliers
Identify Outliers
For a numerical column, identify outliers using standard deviation:
SELECT *
FROM your_table
WHERE column_name > (SELECT AVG(column_name) + 3 * STDDEV(column_name)
FROM your_table)
OR column_name < (SELECT AVG(column_name) - 3 * STDDEV(column_name)
FROM your_table);
Remove Outliers
FROM your_table)
FROM your_table);
5. Data Type Conversion
Convert Data Types
To convert a text column to an integer:
ALTER TABLE your_table
ADD COLUMN new_int_column INTEGER;
UPDATE your_table
SET new_int_column = CAST(old_text_column AS INTEGER);
To convert a text column to a date:
ADD COLUMN new_date_column DATE;
UPDATE your_table
SET new_date_column = CAST(old_text_column AS DATE);
These SQL queries cover practical steps for data cleaning and preparation, essential for ensuring that your data is in the best shape for analysis. Implement these steps directly in your SQL environment to achieve clean, standardized, and ready-to-use datasets.
Joining and Combining Datasets
In SQL, joining and combining datasets is fundamental for enhancing the power of data analysis. Here’s an implementation guide for various types of joins and combinations.
Inner Join
An Inner Join combines rows from two tables where there is a match in the columns specified in the JOIN condition.
SELECT A.column1, A.column2, B.column3
FROM TableA A
INNER JOIN TableB B ON A.common_column = B.common_column;
Left Join
A Left Join returns all rows from the left table and matching rows from the right table. If no match is found, NULL values are returned for columns from the right table.
FROM TableA A
LEFT JOIN TableB B ON A.common_column = B.common_column;
Right Join
A Right Join returns all rows from the right table and matching rows from the left table. If no match is found, NULL values are returned for columns from the left table.
FROM TableA A
RIGHT JOIN TableB B ON A.common_column = B.common_column;
Full Outer Join
A Full Outer Join returns rows when there is a match in one of the tables. If there is no match, the result is NULL on the matching column positions.
FROM TableA A
FULL OUTER JOIN TableB B ON A.common_column = B.common_column;
Cross Join
A Cross Join returns the Cartesian product of the two tables, i.e., it combines each row of the first table with each row of the second table.
SELECT A.column1, B.column3
FROM TableA A
CROSS JOIN TableB B;
Union
Union combines the result-set of two or more SELECT statements. Each SELECT statement within the UNION must have the same number of columns in the same order with similar data types.
SELECT column1, column2 FROM TableA
UNION
SELECT column1, column2 FROM TableB;
Union All
Union All is similar to Union but it includes duplicate rows from both tables.
UNION ALL
Combining Aggregated Data
Combining aggregated data can also be useful:
SELECT A.department, A.total_sales, B.total_expenses
FROM
(SELECT department, SUM(sales) AS total_sales FROM Sales GROUP BY department) A
INNER JOIN
(SELECT department, SUM(expenses) AS total_expenses FROM Expenses GROUP BY department) B
ON A.department = B.department;
Implement these join and combination techniques in your SQL queries to leverage powerful data manipulation capabilities essential for advanced data analysis in data science applications.
Subqueries and Nested Queries in SQL
Subqueries and nested queries are pivotal in SQL for performing complex operations and retrieving advanced data insights. This section covers various practical implementations of subqueries and nested queries.
Subqueries in the SELECT Clause
Example: Select Employees with Salaries Higher Than the Average Salary
SELECT employee_id, employee_name, salary
FROM employees
WHERE salary > (SELECT AVG(salary) FROM employees);
Subqueries in the FROM Clause
Example: List Department Name and Average Salary for each Department
SELECT departments.department_name, avg_dept_salary.avg_salary
FROM departments
JOIN (
SELECT department_id, AVG(salary) as avg_salary
FROM employees
GROUP BY department_id
) as avg_dept_salary
ON departments.department_id = avg_dept_salary.department_id;
Subqueries in the WHERE Clause
Example: Find Employees Who Belong to Departments Located in a Specific City
FROM employees
WHERE department_id IN (
FROM departments
WHERE location = 'New York'
Correlated Subqueries
Example: Find Employees whose Salary is Greater than the Average Salary in Their Department
FROM employees e1
WHERE salary > (
SELECT AVG(salary)
FROM employees e2
WHERE e1.department_id = e2.department_id
Subqueries with EXISTS
Example: Determine Departments with No Employees
SELECT department_name
FROM departments d
WHERE NOT EXISTS (
SELECT 1
FROM employees e
WHERE e.department_id = d.department_id
Subqueries with UPDATE Statements
Example: Increase Salary by 10% for Employees in Departments Located in ‘Chicago’
UPDATE employees
SET salary = salary * 1.10
FROM departments
WHERE location = 'Chicago'
Subqueries and nested queries are powerful features in SQL that enable sophisticated data extraction and manipulation techniques. These examples illustrate their practical applications tailored to data science needs. Each can be directly implemented to gain invaluable insights and execute complex database operations.
Implementing Statistical Functions in SQL
For data science applications, it’s essential to perform various statistical calculations directly within SQL databases. Below are practical implementations of common statistical functions such as mean, median, mode, variance, and standard deviation using SQL.
Mean (Average)
SELECT AVG(column_name) AS mean_value
FROM table_name;
Median
Obtaining the median can be more complex since SQL does not have a built-in median function. The following example demonstrates how to calculate the median using a subquery and window functions.
SELECT
AVG(column_value) AS median_value
FROM (
SELECT
column_name AS column_value,
ROW_NUMBER() OVER (ORDER BY column_name) AS row_num,
COUNT(*) OVER () AS total_rows
FROM table_name
) AS subquery
WHERE row_num IN ((total_rows + 1) / 2, (total_rows + 2) / 2);
Mode
Mode can also require more complex querying since it involves finding the most frequent value(s) in a column.
SELECT column_name AS mode_value
FROM table_name
ORDER BY COUNT(column_name) DESC
LIMIT 1;
Variance
Variance can be calculated using built-in aggregate functions for variation.
SELECT VARIANCE(column_name) AS variance_value
FROM table_name;
Standard Deviation
Standard deviation is often required in data science for understanding data dispersion and can be calculated as follows:
SELECT STDDEV(column_name) AS std_dev_value
FROM table_name;
Example Table and Column
Here are the SQL implementation examples using a hypothetical table sales_data
with a column named sale_amount
Mean
SELECT AVG(sale_amount) AS mean_value
FROM sales_data;
Median
SELECT
FROM (
SELECT
sale_amount AS column_value,
ROW_NUMBER() OVER (ORDER BY sale_amount) AS row_num,
FROM sales_data
) AS subquery
Mode
SELECT sale_amount AS mode_value
FROM sales_data
GROUP BY sale_amount
ORDER BY COUNT(sale_amount) DESC
LIMIT 1;
Variance
SELECT VARIANCE(sale_amount) AS variance_value
FROM sales_data;
Standard Deviation
SELECT STDDEV(sale_amount) AS std_dev_value
FROM sales_data;
Utilize these SQL queries to implement statistical functions directly within your data science projects. These calculations are fundamental for understanding and analyzing your dataset effectively.
Part 9: Performance Optimization and Best Practices
Indexing
Creating indexes on columns that are frequently used in WHERE
, JOIN
, and ORDER BY
clauses can greatly improve query performance.
CREATE INDEX idx_customer_id ON orders (customer_id);
CREATE INDEX idx_order_date ON orders (order_date);
Avoiding Select *
Selecting only the necessary columns reduces the amount of data processed and transferred.
-- Inefficient
SELECT * FROM customers WHERE city = 'New York';
-- Efficient
SELECT customer_id, first_name, last_name, email FROM customers WHERE city = 'New York';
Use EXPLAIN
for Query Analysis
Using EXPLAIN
allows you to understand how SQL queries are executed and identify bottlenecks.
EXPLAIN SELECT customer_id, first_name, last_name FROM customers WHERE city = 'New York';
Proper Use of Joins
Ensure joins are done on indexed columns and use the appropriate join type to match the specific use case.
SELECT
a.order_id,
a.order_date,
b.customer_name
FROM
orders a
JOIN
customers b ON a.customer_id = b.customer_id;
Limiting Data with LIMIT
Limit the number of rows returned when you only need a subset of the data.
SELECT customer_id, first_name, last_name FROM customers WHERE city = 'New York' LIMIT 100;
Using WHERE
Clauses Efficiently
Use WHERE
clauses to filter data as early as possible in the query execution process.
-- Inefficient: No WHERE clause
SELECT * FROM orders;
-- Efficient: Filtered with WHERE clause
SELECT order_id, order_date FROM orders WHERE order_date > '2023-01-01';
Avoiding Complex Expressions in WHERE
Clauses
Avoid using complex expressions that prevent the use of indexes.
-- Inefficient: Complex expression
SELECT * FROM orders WHERE YEAR(order_date) = 2023;
-- Efficient: Use a range
SELECT * FROM orders WHERE order_date BETWEEN '2023-01-01' AND '2023-12-31';
Use of INNER JOIN
vs. OUTER JOIN
Use INNER JOIN
when you need only the matching rows and avoid OUTER JOIN
unless necessary, as it can be more resource-intensive.
-- Inner Join
SELECT orders.order_id, customers.customer_name
FROM orders
INNER JOIN customers ON orders.customer_id = customers.customer_id;
-- Outer Join (use only if necessary)
FROM orders
LEFT JOIN customers ON orders.customer_id = customers.customer_id;
Optimizing GROUP BY
and ORDER BY
Ensure indexed columns are used in GROUP BY
and ORDER BY
clauses.
-- Inefficient
SELECT customer_id, COUNT(*)
FROM orders
ORDER BY COUNT(*) DESC;
-- Efficient
CREATE INDEX idx_customer_id_count ON orders (customer_id);
FROM orders
Avoiding Unnecessary DISTINCT
Only use DISTINCT
when necessary as it requires additional computation.
-- Inefficient: Unnecessary DISTINCT
SELECT DISTINCT customer_id FROM orders WHERE order_date > '2023-01-01';
-- Efficient: If DISTINCT is necessary
SELECT customer_id FROM orders WHERE order_date > '2023-01-01' GROUP BY customer_id;
By following these practices and optimizing your SQL queries, you can significantly enhance the performance and efficiency of your data science applications.
Case Studies and Real-World Applications
Case Study 1: Sales Analytics
Objective:
Analyze a company’s sales performance and identify trends and patterns to improve decision-making.
Real-World Application:
-- Calculate the total sales for each product category.
SELECT
category,
SUM(sales_amount) AS total_sales
FROM
sales
JOIN
products ON sales.product_id = products.product_id
GROUP BY
category;
-- Identify the top 5 products with the highest sales in the last quarter.
SELECT
p.product_name,
SUM(s.sales_amount) AS total_sales
FROM
sales s
JOIN
products p ON s.product_id = p.product_id
WHERE
s.sale_date BETWEEN '2023-07-01' AND '2023-09-30'
GROUP BY
p.product_name
ORDER BY
total_sales DESC
LIMIT
5;
-- Calculate the average monthly sales for each region.
SELECT
region,
AVG(monthly_sales) AS avg_monthly_sales
FROM (
SELECT
region,
DATE_TRUNC('month', sale_date) AS month,
SUM(sales_amount) AS monthly_sales
FROM
sales
JOIN
stores ON sales.store_id = stores.store_id
GROUP BY
region, month
) AS subquery
GROUP BY
region;
Case Study 2: Customer Segmentation
Objective:
Perform customer segmentation to help target marketing campaigns more effectively.
-- Segment customers based on their total spending.
SELECT
customer_id,
CASE
WHEN total_spending < 1000 THEN 'Bronze'
WHEN total_spending BETWEEN 1000 AND 5000 THEN 'Silver'
ELSE 'Gold'
END AS customer_segment
FROM (
SELECT
customer_id,
SUM(sales_amount) AS total_spending
FROM
sales
GROUP BY
customer_id
) AS subquery;
-- Calculate the average purchase frequency per segment.
SELECT
customer_segment,
AVG(purchase_count) AS avg_purchase_frequency
FROM (
SELECT
customer_id,
COUNT(*) AS purchase_count,
CASE
WHEN SUM(sales_amount) < 1000 THEN 'Bronze'
WHEN SUM(sales_amount) BETWEEN 1000 AND 5000 THEN 'Silver'
ELSE 'Gold'
FROM
sales
GROUP BY
customer_id
) AS subquery
GROUP BY
customer_segment;
Case Study 3: Inventory Management
Objective:
Optimize inventory levels by analyzing stock turnover and product demand.
-- Calculate stock turnover ratio for each product.
SELECT
product_id,
SUM(sales_quantity) / AVG(stock_quantity) AS stock_turnover_ratio
FROM
sales
JOIN
inventory ON sales.product_id = inventory.product_id
GROUP BY
product_id;
-- Identify fast-moving and slow-moving products.
SELECT
product_id,
stock_turnover_ratio,
CASE
WHEN stock_turnover_ratio > 5 THEN 'Fast-Moving'
ELSE 'Slow-Moving'
END AS product_movement_category
FROM (
SELECT
product_id,
FROM
sales
JOIN
GROUP BY
product_id
) AS subquery;
-- Forecast future inventory needs based on historical sales data.
SELECT
product_id,
AVG(monthly_sales) AS forecasted_monthly_sales,
AVG(monthly_sales) * 3 AS forecasted_quarterly_sales
FROM (
SELECT
product_id,
SUM(sales_quantity) AS monthly_sales
FROM
sales
GROUP BY
product_id, month
) AS subquery
GROUP BY
product_id;
These SQL queries can be integrated into your educational journey to provide practical and real-world examples of how SQL can be used in data science applications. By working through these case studies, students will gain hands-on experience with SQL techniques designed to solve actual business problems.
