Microsoft Flow String Functions: Concat And Replace
Learning how to combine two or more strings is essential in creating MS flows. In this tutorial, we’ll discuss two of the most important Microsoft flow string functions – concat and replace.
The concat function simply combines two or more strings together and returns the combined string, while the replace function replaces a substring with another string.
For our example, we’ll be using this simple flow that I previously created. First, let’s add another Text input.
Then rename it as Input 2 and the other one as Input 1.
After that, we’ll add a new step.
Search and select the Slack connector.
Then choose the Post message action.
We’ll post it in the discord channel on Slack.
For the Message text, let’s use the concat function under the Expressions tab.
Choose Input 1 and Input 2 as the two strings that we’re going to combine. Make sure to put a comma after choosing Input 1.
Then click the OK button.
Lastly, click Save.
Testing The Concat Function
Let’s now test if the concat function will work. Click Test.
We’ll perform the trigger action and click the Test button.
Enter the following details for the inputs, then click Run flow.
As we check our discord channel in Slack, we’ll see the newly-posted message which is the concatenated version of our inputs for Input 1 and Input 2.
We can also concatenate multiple strings together. For example, let’s go back and edit our flow. Click the function for our Message text then add a space that should be enclosed with a pair of single quotation marks. Then click Update.
Let’s test the flow again.
We’ll just use the data from our previous run. Then click Save & Test.
Upon checking in Slack, we can now see that there’s a space in between the two data entries.
And that’s how simple the concat function works.
Microsoft Flow String Functions: Replace
Let’s now try and understand how the replace function works. Let’s go back and edit our current flow. We’ll replace the first input (Henry) with something else. Under the Expressions tab for our Message text, choose the replace function.
We’ll put the whole concat expression inside the replace function. Put a comma right after the concat expression, then type in the old text that we need to replace. In our case, we’ll replace “Henry”. After that, add another comma and type the new word that we’ll use as a replacement (“Fred”). Then click Update.
Let’s delete the initial expression that we created.
Lastly, click Save.
Testing The Replace Function
Let’s test our flow again. This time, we’ll check if the replace function worked properly.
Let’s just use the data from our previous runs, then click Test.
Let’s go back to the discord channel in Slack. Upon checking, the displayed message is now “Fred Legge”. That means we’ve successfully replaced the initial input that we entered which is “Henry”.
Power Automate Expressions – An Introduction
Power Automate Environment: Setup And Overview
Workflow Inputs In Microsoft Power Automate
To summarize, the concat function simply concatenates two strings together, while the replace function changes the string based on the specified text in the parameter. We can also make the replace function dynamic by using variables for the parameters. For instance, we can use the second input to replace the first input and vice versa.
Hopefully, you were able to understand the usage and importance of these two commonly used Microsoft flow string functions.
Henry
Henry Habib
Henry Habib is an accomplished Power Platform and Office 365 trainer, with over 100 hours of recorded content and over 30,000 paid students on e-learning platforms.
